broken hinge, white screen, How do I get my info off?
Broken L side hinge, screen turned white, haven't synced to my timecapsule in a while. How do I get my info off?
Это хороший вопрос?
Это хороший вопрос?
Assuming that your display is the only problem, you should be able to connect your computer to an external display so you can see what you're doing, and then back it up normally.
Был ли этот ответ полезен?
Both get +.
Plug your time capsule in and boot the machine. Time machine should automatically back it up even if you can't see the screen. Give it a couple of hours to make sure it's completed. Now plug the capsule into another Mac and restore your data via Time Machine. This can also be done from a system installation disk.
+ for the experience working with the hardware to know that
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 1,747
