The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Water Damage - Display + Battery Issue
Hello ifixit!
So the other day a full glass of water tipped onto the keyboard of my Macbook 13. I was quick to act with paper towel, empty the water upside down and turn off immediatly. For 48hrs I kept the computer off with the bottom panel open, battery unplugged and constant fan setup with rice.
The good news is today I was able to successfully power on the computer normally with all trackpad/ keyboard functionality. However there was a quick flash from the screen and then went to black, so I went ahead and plugged in the HDMI port into a monitor, and voila there was still a signal from the GPU. If I had to guess it seems something not with the screen but perhaps the connecting cable.
There also seems to be a problem with that battery as the charger shows it's at 100%, but the computer shuts off instantly when taking off the power adapter. Oddly enough though all the battery information is displayed in the System Report.
On the logic board I see a couple of 2 -5mm water stains. Would it be wise for me to clean with 99% isopropyl on these stains as a potential solution for fixing the screen issue + battery issue? Or do you think these might be deeper issues that need the battery + screen to be replaced.
Any help would be greatly appreciated!
Это хороший вопрос?
Счет -1
Добавить комментарий
2 Ответов
If there are water stains, clean them with alcohol and make sure there is no water in the battery area as your battery may be damaged and could be the source of problems.
Был ли этот ответ полезен?
Счет 0
2 Комментариев:
Thanks for the reply! Should I completely disconnect battery and conduct some tests with the power adapter attached after cleaning stains with the alcohol to try and isolate it?
из
Yea that would be a start :D
Water mainly destructs the regular main of electricity on motherboard traces. Removing any and all water is needed to get the machine working again.
из
Hi guys . My daughter unfortunatelly spilled water on her MacBook Pro 13 Retian early 2015 , she did not tell straightaway she try to used it after dry it with bath towel , however after 1 day i dos not work and I thought for first time maybe in sleep mode like windows laptops and I try to push power buttom down , nothing happened , afer that he told wat happened , I lef it to dry for 2 days and volla it worksagain , buuuuuuuuut what is weird ??? if you power it off and leave it to full , it dos not power on again unless leave it for 1 day or 2 days and then works again , you can carge it when I used it it fine but not when you power it off, and I have to close the lid , ...... Appel store they told me to change the logic board for £650 because they can not power it on even I explaind them everything and they told me they found some liqyid damage on the trackpad board !!! so why I have to change the whole logic board ?? however I can not pay the repair cost ,
I cleaned the trackpad and the rest of logic board with isopropyl and it is workds fine as far as she chrged it when se used it ..... any Idea how and why and wht is damage ??
thanks for reading y comments
Счет 0
Добавьте свой ответ
ErikZ буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 181
