Lenovo Essential G560. This laptop has a 15.6" screen, along with a full keyboard with number pad.
When I start the computer, the screen is blank
Hi, I have a similar issue. When I start the computer, the screen is blank, and I hear the fan goes on and off all the time. The computer wont start (the bios is not starting). If I wait for a long period of time (sometimes even a day or two!!!) it eventually starts, and works fine.
So, unless someone knows how to fix this planned obsolescence issue, I would recommend not to turn the computer off...
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
Hi Idpdrdr,
Have you tried the following:
1. Re-seating the DIMM (RAM) modules.
2. Starting the laptop with the power adapter connected and the battery removed.
3. Starting the laptop with the HDD and ODD removed. (to see if it starts normally, (even if only to get into BIOS) up to the point where it says no hdd detected or something similar.
4. Have you tried connecting an external monitor to see if there is any display at all during start procedure? (can you see the 'backlight' of the lcd screen in your laptop?)
Here is a link to the service manual which shows how to remove / install the memory and how to remove the HDD and ODD. Be sure to do this with the power disconnected and the battery removed.
https://download.lenovo.com/UserFiles/Us...
If your laptop is running I recommend that you 'create a system image' and save it to a USB HDD. That way if you want to try things at least you can restore your laptop to what it was, before you started troubleshooting, once you have hopefully found the problem.
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
ldpdrdr буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 7
За последние 30 дней: 21
За всё время: 539
