Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548вопросов Показать все
Son pulled out sensor wire instead of plug
iMac Intel A1224 emc 2133
I am replacing the power supply to my iMac. I could not disconnect the tiny plug with the thin wire, I asked my son to help (why!) I told him not not pull the wire, but guess what, he pulled out the wire from that tiny plug.
What do I do now? Is there any way of soldering it back in or purchasing that part? Everything else went fine with the disconnection. I just can't afford to buy a new Mac.
Это хороший вопрос?
Оценка 0
3 Комментариев
Step 12, power supply temperature sensor.
из
Step 12, temperature sensor wire.
из
I did this too. What is the solution?
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Here's the guide on replacing the power supply on your machine. Please tell us which wire in which step you pulled? iMac Intel 20" EMC 2133 and 2210 Power Supply Replacement
Был ли этот ответ полезен?
Оценка 4
Step 12 power supply temperature sensor wire.
Оценка 0
Добавьте свой ответ
ladycerridwyn будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 15
За всё время: 126
