The Dell Dimension 2400 is a desktop computer released in 2003 with a traditional box "tower" form factor and a black exterior. It is the last machine from the Dimension 2xxx series and is equipped with a Celeron or Pentium 4 processor.
12вопросов Показать все
Can anyone provide ideas on why my computer will not start?
The computer will not turn on at all. I do not know if some wires have short circulated or if there is a problem with the power source. Can someone give me tips about diagnostic procedures?
Это хороший вопрос?
Оценка 1
1 Комментарий
@unnymonkey what have you tried? Do you have a multimeter? Have you checked the PSU? You will need to give a bit more information.....
Rep: 1
из
Добавить комментарий
1 ответ
Выбранное решение
Start with the a static discharge and work from there . Unplug the computer and hold the power button down for 60 seconds. then plug in the computer and try it .If this brings no joy try removing the ram and trying it with 1 stick at a time .there could be a bad dimm and one will keep the computer from running . If your board is equipped with a mem refresh button now would be a good time to push that. If no joy is near now try replacing the power supply . If you still have no joy then you may need to look at the motherboard or processor. Hope this helps keep us posted
Был ли этот ответ полезен?
Оценка 3
Добавьте свой ответ
Albert Einsteain будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 12
За всё время: 558
