Why does my keyboard stop responding?
Periodically the alphanumeric keys stop responding as I type. The control keys are not affected. I can put the computer in standby mode, bring it back and everything is fine for a while. Is there anything I can do?
Это хороший вопрос?
Счет 0
1 Комментарий:
Hi, Try plugging in and using a USB keyboard. See how it performs. If there are no problems then your keyboard may be failing. Maybe you could try and determine if it is a specific set of keys that are failing so as to isolate the problem, although if it is the keyboard usually it is easier to replace it than to try and fix individual keys.
из
Добавить комментарий
