Компания Apple представила iPhone 5s 10 сентября 2013 года. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 32 или 64 ГБ памяти; в цветах: Серебристый, Золотой и «Серый космос».
Вопросов 20 Показать все
screen cracked and phone body bent
I dropped my Iphone and the screen is shattered. all functions still work as I have a really good screen saver that is not broken so I think I can just replace the glass screen. However, the body of the phone is bent so it is no longer flat. once I remove the screen will I be able to bend this back into place so the new screen will fit properly?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (4)
gövde eğilmiş ise anakart muhtemelen bozulmuştur, yeni bir telefon alman bence daha sağlıklı olur
Был ли этот ответ полезен?
Оценка 0
Yes, you can bend back Iphone frames. Look for youtube tutorials.
BUT, bending metal will decrease strength and could break it. So be careful.
Оценка 0
you should be able to bend it back as long as it does not affect the circuit board and as long as all clips for the screen and screw hold line up there should not be a problem. How badly is the phone bent?
Оценка 0
hello from experience I can say that separate the display from the glass is not easy if you have not experienced a minimum and you can buy for 50 € + display glass. while for the homes it is very folded it is difficult to bend, then you should take it back € 30 million without wiring and comprehensive € 45. to make these interventions there are guides on the site but you have to be a little 'expert and have manual skills and courage. good repair
Оценка 0
Добавьте свой ответ
boatswain2385 будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 3,165
