Inspiron 15-3521 оснащен опциональным сенсорным экраном и 15,6-дюймовым дисплеем. Этот ноутбук также имеет матовую отделку и клавиатуру с цифровым блоком.
No Boot Device Found
Just replaced my hard drive with a new one from ifixit, when running diagnostics it now shows no errors when previously it said there was a problem with the hard drive. On boot up it states: No Boot Device Found. Press any key to reboot machine
On the boot menu after pressing F2, I only have the following options:
LEGACY BOOT: (which is gray)
UEFI BOOT:
When selecting UEFI BOOT:
UEFI Onboard LAN IPv4
UEFI Onboard LAN IPv6
It doesn't seem to matter which order they are in
After reading all other forums, I have not found a solution to this.
Это хороший вопрос?
Счет 1
Добавить комментарий
2 Ответов
Выбранное решение
did you format your drive re-install your Operating system on the new hard drive? When you boot to BIOS check if the hard drive is getting detected there or not. Here are the steps:
Restart the system and immediately start tapping the 'F2' key to enter the 'BIOS'.
Please check what is written next to 'Fixed HDD'.
Double check your installation and your drives compatibility
Был ли этот ответ полезен?
Счет 2
So if I enter f2 and enter bio what next, because my dell is still on fixed HDD ( not detected) . What should I do next?
Счет 0
1 Комментарий:
tucrkilerita what is your computers make and model? This is a new hard drive?
из
Добавьте свой ответ
Karen Chandler буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 18
За все время: 15,376
