A 10.1 inch Polaroid tablet computer with a 1.6 gigahertz processor with a 1024X600 LCD multi-touch display. Released in November 2013.
I can only charge this computer twice
I can only charge this computer twice, in a 24 hour period. That's how long it takes to recharge.
Это хороший вопрос?
Счет 1
1 Комментарий
This doesn't make sense. There is no port left or right. They are all in a row. The mini instructions shows where the USB port is & comes with a too short cord to plug into it. It does charge, but it takes hours to reach 100%. Hense the twice recharging in a 24hr. period.
из
Добавить комментарий
1 ответ
Выбранное решение
Hi armetha1,
The charging port (#3 in the image) should be used to charge the battery as it allows you to connect the AC adapter, which should supply 5VDC 1A (1000mA) to charge the battery. The power output of the adapter should be printed on the adapter.
If the AC adapter cord which plugs into the tablet is too short to comfortably site the tablet for charging near a power outlet, plug the AC adapter into an extension cord which is then plugged into the AC power outlet to give you more flexabilty about where to place the tablet when charging.
Try turning the tablet off when you want to charge it, as this will speed up the charging time.
Trying to charge the tablet via the micro USB port using a USB cable attached to a PC will take twice as long because a PC only supplies 5VDC 0.5A (500mA)
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
armetha1 буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 347
