Полная разборка и инструкции по замене для оригинального iPhone, iPhone 3G, iPhone 3GS, iPhone 4, iPhone 4s, iPhone 5, iPhone 5c, iPhone 5s, iPhone 6, iPhone 6 Plus, iPhone 6s и iPhone 6s Plus.
36476вопросов Показать все
Moisture under glass, effecting retina screen.
I had a headphone jack break off in the iphone 4 audio port. I took it to a Genius he told me Apple would not help and I could use a pen or glue to remove it myself. I attempted removal first via screw to no avail. So then I dared to use super as suggested by the Apple Genius. I place a small amount on the end of the broken jack inserted it with the phone held upside down and then let it stand upright for about an hour. When I attempted to remove the jack it was superglued in place.
Here we now come to my situation and question. I used a slight about of acetone poured directly into the audio port to devolve the glue. It did just enough and the broken jack came out clean. I then blow dried the port and let the phone sit in the sun for a few hours.
The phone works, audio and all, but now it seems through evaporation acetone got under the glass and caused a warping of the screen. It looks dimmer in certain areas like a dirty sheet was wrinkled underneath, behind what is displayed on the screen.
Can I disassemble the iphone and clean the residue away?
P.S. When I press on the glass the darkens spread and is relieved upon releasing of my finger.
Это хороший вопрос?
Оценка -1
Добавить комментарий
1 ответ
Выбранное решение
Sounds like he wasn't much of a Genius. Technically he can't give you that advice, and if he does he is liable for it. (Or Apple is anyways, you can't do anything to him but you can to the company and they can to him.) If he made any disclaimer this wouldn't apply, but if he did you could try fighting it. Most likely you wouldn't win, but legally you have a case.
As far as disassembling, if the residue is simply remaining liquid, then yes you can clean it off. But if there's any damage already done to the display or the glass you may not be able to repair it or would have to replace the part. I wouldn't be able to answer without actually seeing the phone with the screen off as to whether the display is damaged or not.
If it seems like liquid is just moving around in there, I'd say your fine. But if it seems like the picture is changing, as if the electronics or the display is changing like when you press on an older LCD screen, then you may have a problem that cleaning won't fix.
There's no harm in trying if it's something your comfortable doing. If you're not comfortable doing it, I'd recommend finding someone who is. You're not going to do more damage if you're able to put everything back the way it came, as long as you don't spread any of the acetone moisture into the rest of the phone.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Trevor Smith будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 4,897
