Repair guides and troubleshooting for the Acer Aspire 5750. This is a 2012 Aspire budget laptop aimed at the casual household user or for small business use.
acer screen gets white after starting
Just as I push power button screen goes white and a small portion in right side of screen has a black color.
Laptop detail
Aspire 5750 series
Model no P5WEO
Os:Window10/ 32 bits
Это хороший вопрос?
Оценка 0
2 Комментариев
Hi, Try connecting an external monitor and see what it shows.
из
External monitor is working very well...
из
Добавить комментарий
Ответов (1)
Выбранное решение
Hi,
It is either the LCD screen or the flex cable that connects it to the motherboard that has the problem. Check the flex cable connections in case they have come loose.
Here is a link to the service manual for your laptop. It details how to remove all the various components, including the screen module from your laptop. Hopefully this will help you to isolate your problem. (ignore the title at the top where it says Acer Aspire 5350 Service manual, scroll down and you will see it is the correct one, obviously a typing error).
http://www.manualslib.com/manual/269241/... 5750G
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
mushke azam будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 3
За последние 30 дней: 3
За всё время: 257
