Where is Wi-Fi antenna in Asus T100? Wi-Fi is too bad
Asus T100TA connects to Wi-Fi only in 2 meters. Want to search hardware problem
Это хороший вопрос?
Это хороший вопрос?
Hi,
Here is a link which I hope will help you.
It shows the dis-assembly of an Asus T100. At 4:35 minutes into the video it shows the start of the removal of the WiFi antenna bracket (so that the motherboard can be removed- the video is for a screen replacement) and you can see the associated antenna cable.
https://www.youtube.com/watch?v=IBo8Qwfm...
Here is a link that shows just one supplier of a Asus T100TA WiFi antenna cable. If you click on the Cable link and then scroll down to the bottom you will find the WiFi antenna part.
http://www.asusparts.eu/en/partfinder/As...
Here is the Asus T100TA part number for the WiFi antenna cable, 14007-01430300. If you "Google' the part number you will find other suppliers.
hopefully this is of some help.
Был ли этот ответ полезен?
Thanx!
I found some images on Ebay with words "Asus T100TA WiFi antenna cable"
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 2,264
