How to delete and add in new phone number
How do I delete number and put new number into phone book?
Это хороший вопрос?
Это хороший вопрос?
Hi,
To delete a number from the Phonebook
1. Press the Phonebook button to open the list.
2. Use the Up and Down arrow buttons to scroll thru the list to find the wanted number.
3. You now have 2 choices:
a) Edit the entry so that you create a new entry - Press the Menu/Select button then select Edit and enter the new information.
b) Delete the entry - Press the Menu/Select button then select Delete, wait for the phone to ask for confirmation, then select Yes
To create a new entry in the Phonebook - Press the Phonebook button to open the list, press the Menu/Select button then select Create New then enter the information.
Here is a link to the User Guide for your phone.
Был ли этот ответ полезен?
The link no longer works but thank you for your comment :) stay safe.
Hi @ darrenashley23,
Thank you.
I've amended the link to the user guide to one that works.
Cheers
Hi @Lenny Gid,
Try the following and see if it works.
Press Redial/Pause > Scroll through the redial list to find the wanted number (use Up/Down button) > when the number wanted is highlighted > Press Menu/Select > Delete Entry.
To delete all the numbers stored in the Redial list follow the procedure above but select Delete All
За последние 24 часов: 1
За последние 7 дней: 14
За последние 30 дней: 76
За всё время: 53,011
4 Комментариев
how do i delete all phone numbers that i have called from my uniden dect 2145 phone? (these are not stored by me but show up when i press the redial button)
из Lenny Gid
dont want anyone else checking on my recent calls , the hand set has a redial button that shows all calls made from this phone , how do i delete all not stored numbers bank details etc made on the hand set , thank you
из Lenny Gid
How do I delete a phone number on At&t landline
из georgie Meyer
@georgie Meyer ,
What is the make and model number of the phone if it is not a Uniden D1760?
из jayeff
