This Nintendo DS Lite was released in 2006 as the successor to the Nintendo DS. Getting inside this device is simple, making for easy fixes.
Charge Port Got Problem
is it expensive to just change the charging port of ds lite?
Это хороший вопрос?
Счет -1
1 Комментарий:
Getting the part should be no problem and is cheap to buy. The hard part is soldering the new charger port on. Not sure how much repair shops would charge you to repair this. I do them for about $30-$40.
из
Добавить комментарий
1 ответ
If you want to replace it yourself, the part isn't that expensive.
I've seen them pop up from 3 to 8 euro's / dollars on eBay, it all depends on the supplier.
But if someone else has to do it, it will cost you around 30 or something like that.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Faiz Ajan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 95
