Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
794вопросов Показать все
Are Torx Security bits compatible with non-security bits?
I am looking to upgrade my wife's old Macbook Pro with an SSD, following this guide: MacBook Pro 13" Unibody Mid 2010 Hard Drive Replacement
It says we need a T6 Torx screwdriver. I thought it was weird that the driver kits being sold by iFixIt wouldn't include anything higher than T5 for non-security Torx bits, but then I saw the following on this page: TR6 Torx Security Screwdriver
"Security drilling on this driver makes sure that you won't be stopped by anything, even though this driver still works great in non-security T6 screws as well."
So, can anyone confirm if Torx Security bits are compatible with Torx non-security bits, and does this hold true for all Torx bit sizes?
TR6 Torx Security Screwdriver Изображение
Продукт
$5.99
Это хороший вопрос?
Оценка 9
Добавить комментарий
2 Ответов
Выбранное решение
The difference between security torx and standard torx is the hole drilled in the center, this allows the driver to slip over the pin located on the security screws. Otherwise they are identical sizes.
Был ли этот ответ полезен?
Оценка 5
1 Комментарий:
is just the hole the difference? both share the same sizes?
из
Наиболее полезный ответ
Of course they are, all it is, is an extra hole.
Оценка 7
Добавьте свой ответ
Help Computer будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 20
За последние 30 дней: 90
За всё время: 24,076
