The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
Where is the fuel filter?
location of fuel filter?
Это хороший вопрос?
Счет 2
2 Комментариев
gas or diesel ?
из
Thanks for the help.
из
Добавить комментарий
1 ответ
Выбранное решение
Depending on the year of the truck if its gas or diesel there are several locations . On the diesel its located next to the master brake cylinder. On older gas models its mounted on top of the fuel tank next to the sender unit on some of the newer models its mounted to the frame rail next to the fuel tank . Easiest way to find it is to start at the fuel tank sender unit and follow the fuel lines to the engine. you'll find it in there somewhere. If your not seeing it odds are its one of the ones mounted on top of the fuel tank. Hope this helps
Был ли этот ответ полезен?
Счет 5
Добавьте свой ответ
Terry буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 20
За последние 30 дней: 84
За всё время: 28,575
