I can barely see the screen
I can barely see the screen and adjusting it makes no difference
Это хороший вопрос?
Это хороший вопрос?
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
Был ли этот ответ полезен?
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
Did you replace those?
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 532
