guide for replacing LCD screen
I cannot find a guide for replacing the LCD screen on 17" unibody.
Это хороший вопрос?
Это хороший вопрос?
This GUIDE for the 15" model should suit you fine. It's basically the same thing.
Был ли этот ответ полезен?
The screws for the 17-inch Macbook Pro Unibody are underneath the bottom two corners of the assembly, under the rubber "gasket" if you will. If you take your fingernail, you can peel back the rubber about an inch from the corner of the LCD (an inch towards where it would say "Macbook Pro" if the glass was still attached).
Trevor - [URL|http://www.CrackedMacScreen.com]
hey trevor, wanted to thank you for giving that bit of info, never would have guessed apple hid the LCD screws behind there.
If i saw this first i wold know where the screws... %%** lol
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 1,762
1 Комментарий
It did help but the screw location on the 17" is not the same so I have two screws securing the LCD that are not accessible without more information.
из Martin Lee
