Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212вопросов Показать все
Intel iMac as an external monitor - Guide
I had a 2006 Intel iMac that died (logic board / graphics card failure) and instead of consigning it to the bin, I aimed to turn it both an external monitor for my screen-less 2009 MacBook Pro (LCD driver failure, failing battery) and any HDMI device I wanted. I had seen this done with G5 iMacs, but never with Intel ones, which use different display types, so decided to have a go and was successful!
My guide can be found in the answer...
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Guide of how I did it - http://www.instructables.com/id/Intel-IM...
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
@moomike - Michael - Sadly all of your work here won't be found if you just post it here. The best thing to do is create a IFIXIT guide that way someone who also wants to do the same thing can find your efforts. Follow this link: Create an IFIXIT Guide
из
Добавьте свой ответ
Michael будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 226
