Model M6497 or A1005 / 500, 600, 700, 800, or 900 MHz G3 processor
117вопросов Показать все
Graphics Issue
I am having a Graphics issue with an iBook G3, the graphics keeps causing the Screen to either go blank or go White with 2 Blue Strips down it, Please reply with a fix and possible a pic for demonstration
Это хороший вопрос?
Оценка 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
unfortunately you are probably experiencing a common issue with this series - the graphics processor either fails or its solder joints to the logic board become loose.
some have had success using non-conductive material (folder paper square, etc) to create a shim between the chip and the case, causing force and pressure to hold the chip stable. others have been able to get the chip solder reflowed.
see these existing answers:
Why does my iBook randomly freeze?
Display Screen stays black, but computer still works good
Был ли этот ответ полезен?
Оценка 1
You could check this out.
http://cgi.ebay.com/iBook-G3-Logic-Board...
Оценка 0
Thanks everyone
Оценка 0
Добавьте свой ответ
Darth Seleyus будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 4
За последние 30 дней: 5
За всё время: 1,379
