Модель M6497 или A1005 / процессор G3 с частотой 500, 600, 700, 800 или 900 МГц
Graphics Issue
I am having a Graphics issue with an iBook G3, the graphics keeps causing the Screen to either go blank or go White with 2 Blue Strips down it, Please reply with a fix and possible a pic for demonstration
Это хороший вопрос?
Счет 1
Добавить комментарий
3 Ответов
Наиболее полезный ответ
unfortunately you are probably experiencing a common issue with this series - the graphics processor either fails or its solder joints to the logic board become loose.
some have had success using non-conductive material (folder paper square, etc) to create a shim between the chip and the case, causing force and pressure to hold the chip stable. others have been able to get the chip solder reflowed.
see these existing answers:
Why does my iBook randomly freeze?
Display Screen stays black, but computer still works good
Был ли этот ответ полезен?
Счет 1
You could check this out.
http://cgi.ebay.com/iBook-G3-Logic-Board...
Счет 0
Thanks everyone
Счет 0
Добавьте свой ответ
Darth Seleyus буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 13
За все время: 1,775
