Этот дрон поддерживает Wi-Fi и оснащен встроенной HD-камерой. Он используется для фото- и видеосъемки. Номер модели: PF722000
The light on the drone blinks green then turns red
After I had an accident in which my Parrot Bebop fell about 75 feet, I could not turn the drone on again. When I pressed the rear light to start the drone, first the light blinked green and then turned red.
I at first thought the problem was one motor that had been damaged. I replaced the motor in question, but the light still blinked green and turned red.
Eventually, I took the drone removing the motors, camera, and gps until there was only the motherboard connected to the battery. Now, I still get the same response. When I press the turn on button the light blinks green and then turns red.
Do you have any suggestions for repairing this Parrot Bebop?
Это хороший вопрос?
Счет 2
1 Комментарий:
Have you found a solution? I have the same problem and am unable to find a cure anywhere.
из
Добавить комментарий
2 Ответов
This has to do with either
Disconnected motor
Or disconnected GPS board
Был ли этот ответ полезен?
Счет 0
i am working on mine right now and it seems that the motor drivers have an open ground or negative, when powering on the motors should activate a few short pulses. my drone does not, but you know guys it would be a !&&* of a lot easier if they would supply a circuit diagram
Счет 0
1 Комментарий:
Okay, so I took the drone completely apart and searched for any connections that might be questionable. I did not find any obvious issues, just for being able to say that I did something I reflowed the power connections to the mainboard and reassembled the drone. It is working again. Very nice construction of the mainboard. I would say, it's probably 5 layers thick.
из
Добавьте свой ответ
cmitc буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 1
За последние 30 дней: 22
За все время: 3,398
