Why is my front right Indicator not working,bulb ok
I have a XL1200 Harley Davidson Sportster 2012
It came on yesterday 9/6/2016 as i was turning right,then suddenly went out and on dashboard little green arrow flashing rapid?
Это хороший вопрос?
Это хороший вопрос?
Check the rear bulb as well when one goes the other acts weird so check to see if the rear bulb is bad
Был ли этот ответ полезен?
Thanks Jim i will check rear indicator just in case that is the fault.:)
Sam "little green arrow flashing rapid" is caused by the indicator not working. Make sure that the bulb is indeed okay, I'd replace it anyway. If a new bulb is not working as well, check the wiring going to the indicator. Make sure that it shows continuity.
Funny enough the indicator decided to work in the rain,touch wood its still working now,but i will check back indicator like you said,thanks oldturkey :)
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,551
