wipers not working on a 04 honda accord
why are my wipers not working I replaced the underhood fuse box twice with used ones and the swith
Это хороший вопрос?
Это хороший вопрос?
There are a lot of reasons for your wipers not working but first I must ask why did you replace the entire fuse box or are you replacing just the fuse? Have you tested to see if there's power at the wiper motor ? Checked the switches for power on each side of the switch. Checked the wiring for continuity? A multi meter or test light goes a long way to helping diagnose your problem .
Был ли этот ответ полезен?
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 2,096
1 Комментарий
@waldo63 did it ever worked with new fuses? Did the fuses blow? Did you replace the switch? What else have you checked?
из oldturkey03
