Repair guides and disassembly information for Huawei's Android-based smartphones.
1882вопросов Показать все
Internal storage damaged and is now unavailable
Everytime I turn my phone on it always says "internal storage damaged and is now unavailable. Please choose one if the following"
A) restore factory settings
- but it won't let me choose this option.
B) restart phone
- I've already done it but it has gone back to the same thing.
Это хороший вопрос?
Оценка 28
4 Комментариев
what is the solution this problem huawie internal storage is damage
из
If you can do a factory reset then attempt it this may repair the problem but in most cases the memory in the phone is corrupted and not repairable . If you can preform a factory reset you will lose all your data but you will have a usable phone again .
из
wipe data wil solve your problem but you will lose your data tested by me
из
@emanco80 he does not need the data tested by you, so I think it's fine if he looses that! :)) learn how to write first, idiot! and no, it will not solve the problem! how can a data wipe repair broken memory clusters? just go away man
из
Добавить комментарий
1 ответ
Выбранное решение
probelm with EMMC IC no way to repair only change IC
Был ли этот ответ полезен?
Оценка 8
Добавьте свой ответ
kaycee ngawhika будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 15,860
