Обновленная версия iPhone 3G с более высокой скоростью обработки. Ремонт этого устройства схож с iPhone 3G, и требует простых отверток и инструментов для вскрытия. Модель A1303; 16 или 32 ГБ памяти; с Черной или Белой задней пластиковой крышкой.
1500вопросов Показать все
Backlite is gone, not display issue
Hi!
Some time ago I replaced a screen on 3GS. That unit was bad as I discovered later, any pressure applied to top right corner of the screen was shorting backlite led + and - than backlite turns off. After lock/unlock it restored, but only untill I touched that corner again. So once again it didn't do back. I replaced the screen, no luck. Than I went with this scheme
and tried to replace 6R8 coil, no changes. Than I wired 3rd display connector pin with third pin on ic (if I call it right). Nothing changed. Than I wired 2nd display connector pin to the contacts on the back. And nothing again. I jumped all resistors and filters I could but no backlite :|
Guys, please, help my find out what's wrong there and how to fix it?
Это хороший вопрос?
Оценка 0
1 Комментарий
Anybody?..
I'm without a phone at all :\
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Since you know which pins to short, you probably have the schematics, so here are the basics: the backlight circuit in 3GS consists of a power inductor, a transistor driven by the power controller chip, and a small filter inductor. The first two form a DC-DC converter which rises battery voltage to a level sufficient to power backlight (don't have an oscilloscope right now to tell you the exact value), shorting the coil is not a really good idea, the converter simply won't work.
The coil usually dies first, but if you're adamant it's OK, you can also try replacing the transistor (on the right to the coil on your pic, marked with yellow "2"), it's FDFMA3N109 by Fairchild Semiconductor, a diode and an N-FET in a single case. They're still in production, you should be lucky. Please be advised: it has 2 additional pads on its "belly", so soldering's gonna be fun if you never tried that before.
Был ли этот ответ полезен?
Оценка 1
Nobody had the same issue? No servicemen here?
Оценка 0
Добавьте свой ответ
Anri будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 105
