Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408вопросов Показать все
Why is my lcd showing a dim light after replacement
So I replaced my lcd on my iPad 4 everything seem to went well the first time but I noticed parts of the screen wasn't working so I took it apart again but this time when I reassembled it the lcd turned on but it was a dim black light and it wasn't showing no picture I'm not sure what to do please help
Это хороший вопрос?
Оценка 0
3 Комментариев:
Did you turn off the iPad when unplugging the LCD and replugging it?
I'm not 100% sure if unplugging the battery is required as well.
из
No I didn't completely turn it off but I did a hard reset and that still did not solve the problem
из
So right now it is showing no display but a dim backlight around the screen or something along the lines of that? Could be backlight fuse(s) blown or if unlucky LCD ribbon cable gone bad.
из
Добавить комментарий
1 ответ
I have wrote a blog about the similar problem on iPhone. It may give you some help.
Why iPhone Screen Dim after Screen Replacement
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
lateef ambali будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 71
