The paper will not feed
The printer will not pick up paper and/or an evelope
Это хороший вопрос?
Это хороший вопрос?
Paper dust accumulates over many years of use and coats the rollers thus they slip.
Clean the pickup rollers.
There are special sheets that can be purchased to do this.
Works for my ancient HP LaserJet 1200.
Был ли этот ответ полезен?
In most cases, whenever a printer won’t pickup paper, it is usually because of the pickup rollers. I would recommend going to hp.com and searching for your specific printer model. Look for the part lists and find the part number for the pickup roller. Note, most printers have at least two trays. One is where you load most of your paper and the other for the manual paper tray. You want to make sure you change the rollers for the tray that is giving you the most problem.
You can also verify this to be a problem if you touch the rollers. If they’re really smooth, it won’t grab the paper. Rollers should be almost tacky.
Finally, you can try different paper or fanning the paper so that it’s not sticking to one another.
Good luck.
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 14
За всё время: 2,805
2 Комментариев
this did not fix it. The paper roller will not pick up paper to print. Goes through the motions but does not grab the paper.
из Greg Frantal
A piece of paper is stuck in the printer and wont come out.
из pythianpcg
