The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730вопросов Показать все
Could heat from heat gun misalign Home button and data port?
After a 3rd attempt everything went smoothly or so I thought I used a low setting heat gun as instructed in a video to seal the adhesive, I may have gotten too close to the power/data port and home button, because after 4 hours of waiting for the adhesive to bond I started to notice first that the Home button didn't respond, I tried to reset settings no luck, and then I found when I plugged it in it won't charge unless pressure is put on the screen near the port like in this video https://www.youtube.com/watch?v=c5damnSS... but much worse, the home button does respond when pressure is applied, is it possible the heat unseated the board or worse yet bent it somehow with the heat? Am I pretty much screwed and now need a new logic board or do I just need to reopen, seat the board correctly and close up with new adhesive? I forgot to say everything else works fine. Upon further inspection it did not seal properly I can see visually that it appears the area of the button and connector is not in alignment. The bezel is still good so I can reuse, after applying pressure again it is now charging, obviously this is long out of warranty so I can't get a replacement, I'm using an assistive Home button at the moment, it can limp along like this but would be better if it worked the way is supposed to. Please tell me what you think is wrong.
Thanks
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I wouldn't jump to conclusions like the logic board being at fault before trying to replace the cheaper components such as the charging dock and the home button assembly first.
You can get the home button assembly from here:
iPad 2nd and 3rd Gen Home Button Assembly
You can get the iPad 2 dock connector here:
iPad 2 Dock Connector
Guide to replace home button:
iPad 2 GSM Home Button Assembly Replacement
Guide to replace dock connector:
iPad 2 GSM Dock Connector Replacement
iPad 2 Dock Connector Изображение
Продукт
$19.99
iPad 2nd and 3rd Gen Home Button Assembly Изображение
Продукт
$12.99
iPad 2 GSM Dock Connector Изображение
Инструкция
Сложность:
Сложно
iPad 2 GSM Home Button Assembly Изображение
Инструкция
Сложность:
Очень сложно
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
I really don't think replacing those parts is going to do it, seeing how with applying pressure they both appear to function, I'm more inclined to believe the board was affected when the heat was applied.
из
Heat can cause the plastic in the charging port to warp which sounds like thats what happened here as now you can not fully insert the charging port to charge the unit. Unless you put pressure on it.
Did you get a new screen with adhesive and a home button already on the new screen? Or did you transfer the home button to the new screen?
Оценка 2
1 Комментарий:
Yes it's a new screen with adhesive and a home button already on it, so then it could have possibly warped the home button as well. That would make sense, given the pressure needed to make them work, I still have a home button from a previous screen I could try, but I would have to get a power port replacement, I guess I will have to try that and see what happens. Thanks for the answer. I just need to clarify the I can insert the plug fully into the charging port but it takes the pressure for it to charge.
из
Добавьте свой ответ
Ken будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 122
