ip6 stuck in headphone mode after lightning/headphone jack replacement
Hello,
My iphone 6 was stuck in headphone mode after some water got in the headphone jack (phone was on wet lawn after sprinklers). I replaced the lightning/headphone jack after purchasing the new component from ifixit, but I'm still have the same problem after the repair. The repair seemed to go smoothly otherwise. Does anyone have any experience/suggestions with this?
Thanks!
Brian
Это хороший вопрос?
4 Комментариев
bump, any suggestions?
The following post seems slightly related in that changing the jack did not fix his problem relating to the headphone jack.
Headphone jack not working
из daobox
Water damage on the logic board most likely.
из Ben
That or, not that it happens often but have you tried another part just to rule out it possibly being defective?
из Shaina O
Sometimes iPhone stuck in Headphones mode preventing you from hearing the sound. The problem is that iPhone mistakenly acts as if headphones are plugged in.
Here i found a usefull article on
http://bbcpak.com/2016/11/iphone-stuck-h...
из Atif Mallo
