Anyone having a Nikon MD-12 Repair Manual, Wiring Diagram or Picture?
I have an old analog Nikon camera with a MD-12 Motor Drive in which three electrical wires have released from their soldering.
I wonder if you could please help me with a pdf repair manual or a picture of the wiring diagram for the circuit board that is connected to the shutter release switch? The wiring diagram is in the repair manual but an ordinary picture of a circuit board with the cables attached is also OK.
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
@ostlind this is going to be tough since we cannot see which PCB this is and where the wires are coming from or going to. A total view of the board would help, but I can imagine that it will be a PITA to completely remove it. Something like this
would help us to help you:-)
Anyhow, this will definitely help you out since it contains everything you need md12sm.pdf Make sure that you create a couple of guides when you repair this. It will come in handy for other people looking for answers like you.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
Thanks @oldturkey03 for the manual, it solved my problem! I already had the motor disassembled so there where no point in making a guide but I'll keep it in mind for upcoming objects!
из
Добавьте свой ответ
Sven Ostlind будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 28
За всё время: 1,974
