Repeats 1234 error code on display screen
We had a severe storm which resulted in a power outage for about 24 hours. When the power went on, our microwave started to run though numbers on the display screen. 1 2 3 4. It runs through each number about 4 times until it stops on 1.
Update (07/24/2016)
It's a Kenmore model number 721.80032700.
Это хороший вопрос?
Счет 0
4 Комментариев
What microwave is it. Make and model number please
из
Thank you, I will try it.
из
That worked! Thank you for your help.
из
Glad I could help ;-)
из
Добавить комментарий
1 ответ
Выбранное решение
Sometimes shutting off the circuit breaker that the microwave oven is connected to for 30 seconds will clear the fault, error or function code; however, there are some cases when further service may be required.
http://products.geappliances.com/applian...
Был ли этот ответ полезен?
Счет 1
Добавьте свой ответ
Jackie Dobransky буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 2
За последние 30 дней: 5
За всё время: 321
