The Philips Norelco Shaver 3100 is an all-in-one styling trimmer. It has multiple attachments for all your grooming needs. It is identified by model number QG3330/60.
7вопросов Показать все
Where can ii get a replacement battery
Battery is dying - where can i get a replacement
15v 5.4w 1310/A
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Try batterupgrade.com, send them an email.
Good luck!
Был ли этот ответ полезен?
Оценка 0
You can go to a battery shop such as Batteries Plus. They can change the battery for you or you can do it yourself. It requires care in disassembly and reassembly but when shavers cost $100.+ dollars, it's worth it.
Оценка 0
I had this same issue with mine (Phillips Norelco Multigroom, not a 3100 model but one with a turbo button on it) and when I took it apart (great tutorial on Ifixit.com) I discovered that it is just 2 AAA batteries soldered in. I just purchased a set of them at my local store and soldered them in. Works great again.
Оценка 0
Добавьте свой ответ
Lenny Romeo будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 6
За всё время: 1,419
