This Power Mac G4 has Mirrored Drive Doors.
80вопросов Показать все
freezes when coming out of sleep mode
computer freezes when taken out of sleep mode and at times
when starting, a large box appears in middle of screen, and its in a lot of different languages and in american it says to restart or quit, but you can not cause functions are frozen. Only way to shut down and restart is by holding down start button on front of CPU.
this problem happens often, we installed a new hard drive thinking it was problem ,But was not.
thanks for any insight !
Это хороший вопрос?
Оценка -1
1 Комментарий
thank you ! heads me into the right direction.
из
Добавить комментарий
2 Ответов
Выбранное решение
You seem to be experiencing kernel panic. I would first remove and reinstall the video card and if that did not cure the problem I would remove and swap the memory around. Good luck.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
+ good start
из
I have a Powermac MDD Dual 1.42 that's been suffering from sleep issues and random kernel panics, under Tiger and Leopard. After several troubleshooting sessions with both hardware and software, I decided to go back and reinstall Panther. My sleep issues and kernel panics have apparently gone away...go figure. Panther is a tad slower than Tiger and Leopard, but I'll take stability over speed any day. Hope this can help someone :)
Sincerely,
Renick Marsh
www.CoolStuffZone.com
My computer:
Powermac MDD Dual G4 1.42 GHZ
2 GB RAM
Radeon 9800 Pro
Acard 320 GB RAID
Belkin USB 2 Card
Оценка 0
Добавьте свой ответ
Hugh будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 1,026
