Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
487вопросов Показать все
Pulsing blue light and black screen are keeping it from turning on
My phone fell. The screen is not cracked however the screen is black and the blue light dims in and out. The phone charges, as indicated by the red light when plugged in. Is there any way to get it to turn on?
Это хороший вопрос?
Оценка 4
3 Комментариев:
Plug it into your computer and see if the computer recognizes it. If it does, its just a display issue. Follow the guide to remove the screen and make sure the LCD connector is seated properly. If it is, you just need a new display.
из
I plugged the device into a computer (via the charger) but the computer does not recognize, or say that the phone is in.
из
Hey did you get it fixed? What was the problem?Same thing happened to me yesterday and i am confused.
из
Добавить комментарий
2 Ответов
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
same problem here, how did you fix it ??
из
You would try a soft reset press volume down and power button together for a few seconds to see if it boots up failing that u would try a new screen
Heres a handy dandy guide on replacing the screen
Samsung Galaxy S6 Screen Replacement
Оценка 0
Добавьте свой ответ
Stacy Walton будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 10
За последние 30 дней: 51
За всё время: 9,911
