My radio is in a rebooting loop
I have a Kenwood DNX 9990HD radio and when i turn it on it just keeps rebooting.
Это хороший вопрос?
Это хороший вопрос?
Hi
Have you tried resetting the device?
Here is an image that shows how. (apologies for the poor quality)
If that doesn't work try removing all the power from the device , press and hold the on button for 10 seconds to drain residual power, then re apply the power supplies and see if it starts normally.
If the reset or power refresh works you may wish to check that the firmware is up to date.
Here is a link that shows the models that the firmware is for. In it, there is a link to a guide on how to install the firmware (take note of the precautions at the bottom of the guide) as well as a link to download the firmware file.
Был ли этот ответ полезен?
I tried to reset it but that didn't work either
Hi, Since you have got nothing to lose, try updating the firmware as per the guide. I know with some TVs that when you power it on the first thing that it does is look at the external USB or MMC port to see if there is a file there with the correct name for a firmware update. Perhaps your radio is the same. Download the firmware file, install it in the root directory of the USB drive (i.e. don't put it in a sub folder on the drive) and then plug the USB into the radio and switch on and see what happens.
I will try that thank you
No luck its still in the rebooting loop, thank you for the help, do you have any other suggestions
Hi, My only suggestion now is to contact Kenwood Home and Car products, (here is a link if you are in the USA of course http://www.kenwood.com/usa/about/ ) and ask to speak to someone in Technical support regarding whether there is a 'fix' for a bootloop problem in your model device. It never hurts to ask and you may be surprised by the answer. At least you will know.
If you go to Karstens Audio Works on Facebook,you will see that I have reflashed various Kenwood navigation units from the other side of the world.
Can someone post a pic of the daughter board? I have 2 units trying to fix one. One doesnt try to boot even with a reset. The other is stuck in a reboot loop.
What are the model numbers of the units? If they are navigation units,the daughter board is located under the CD mechanism. You can check out a few of my overseas clients who I reflashed their Kenwood Navigation units for on Karstens Audio on Facebook.
За последние 24часов: 6
За последние 7 дней: 74
За последние 30 дней: 379
За всё время: 62,133
13 Комментариев
just installed a DMX7704S in my 2004 Acura MDX with Sirius, and it keeps rebooting. Took it in and they replaced the unit, still having the problem.
из Jim Caratozzolo
i have a kenwood DNX 8980 That is stuck in a reboot loop what do i do to fix it
из deweyshottenkirk
I have a kdc-138 and it is stuck in a reboot loop.. what do I do
из Rusty Highsmith
I'm not familiar with the KDC series, but I have managed to repair a DNX6190HD(same as 6990HD, 7190HD, 9990HD), by replacing the nand flash on the pc board, it's a Toshiba IC(TC58NVGIS3ETAI0). pacparts.com, or eastcoasttransistors.com have the part, not cheap though(with software on it), ~$60. You also need to know, the part number from the board.
из Tibor Makai
I have the same problem with my kenwood ddx9702s. It may reboot 4 times in a row then it might not do it for 2 days. I was hoping to find a way to resolve it other than going to a Kenwood service center. I do not have one close by. I would like to do a factory reset but I cannot figure out how.
из Gary LeCureux
Показать 8 больше комментариев
