iPod Touch 5th Generation
So the problem with my iPod is that it won't charge like for example ur battery is at 20% it would stay there it won't charge at all I don't know if it is my charger or its my iPod
Это хороший вопрос?
Это хороший вопрос?
Hi,
Without knowing more details about your ipod (if you dropped it, spilled water on it, bent the charging port etc), these are my suggestions:
The first thing to try would be a different charger and a different outlet, to ensure that those are not the culprits.
Batteries do have a limited life span; after a certain number of charges (~2000) they will start to fail until they eventually can't hold a charge anymore. You could be due for a battery replacement. This guide, up through step 16, outlines how to do this.
iPod Touch 5th Generation Logic Board Assembly Replacement
You could also have an issue with the charging port, a replacement is outlined here, through step 27.
iPod Touch 5th Generation Rear Case Replacement
Good luck!
Инструкция
Сложность:
Сложно
1 - 3 hours
Инструкция
Сложность:
Сложно
Был ли этот ответ полезен?
Great answer! You need some more rep!
I think you should check your charger on another apple device to see if it charges that and if it doesn't its not your ipod its your charger
This has already been resolved and accepted.
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 7
За всё время: 187
