Repair information for the Brother MFC-J6920DW wireless, multifunction inkjet printer. Model number: MFC-J6920DW. First available on Amazon in September of 2012.
Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Это хороший вопрос?
Счет 2
3 Комментариев
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
из
Re-aligning print heads doesn't solve the problem....
из
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
из
Добавить комментарий
2 Ответов
Выбранное решение
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
Был ли этот ответ полезен?
Счет 2
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
Счет 0
1 Комментарий:
I ran the cleaning cycle several times and it didn't help. Does the printer head need to be changed?
из
Добавьте свой ответ
Khemchand Ramcharan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 7
За последние 30 дней: 25
За всё время: 4,839
