The slim edition of the classic Xbox 360 with a 250GB HDD and built-in Wi-Fi. Repair requires intricate prying and special tools.
HDMI output not working
Is there any fix for the hdmi output as this has stopped working, I've had to resort to using the RCA connections/start adapter which has reduced the quality of the picture. Any help will be greatly appreciated.
Это хороший вопрос?
Счет 0
2 Комментариев:
Have you checked the input device and cable?
из
Cable works fine as use it on Wii-U, tv is fine too
из
Добавить комментарий
1 ответ
You can try resetting the system software, but other than that, the only solution would be to replace the motherboard.
Был ли этот ответ полезен?
Счет 0
Добавьте свой ответ
Ian Clarke буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 7
За всё время: 144
