The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26вопросов Показать все
Why did my computer froze?
I was working on my online quiz and it froze on me my mouse was pointed at the scroll down area.
Это хороший вопрос?
Оценка 0
1 Комментарий
amiller364 there are lots of reasons for why this may have happened. Did you get it restarted? Any issues with doing that?
из
Добавить комментарий
2 Ответов
Выбранное решение
amiller, Shut down ( hold power button 10 seconds) and restart, run a malware and virus check as this could be an infection.
I hope this helped you out, if so let me know by pressing the helpful button. Good luck.
https://chromebook.guide/chromebook-viru...
Был ли этот ответ полезен?
Оценка 1
Also look into running a power flush on your device. This can be achieved by following Googles Chromebook reset instructions:
(In your case you would shut it down and use the keyboard short cut in the login screen)
Sign out of your Chromebook.
Press and hold Ctrl + Alt + Shift + R.
Click Restart to restart your Chromebook.
In the box that appears, click Reset and sign in with your Google Account.
Note: The account you sign in with after you reset your Chromebook will be the owner account.
Follow the instructions in the box.
Once you've set up your Chromebook, check if the problem is fixed.
THIS WILL RESET YOUR CHROMEBOOK but being a google device all your pictures, documents and the like should be online in the google drive.
This will fix %95 of software issues.
If it does not look into creating and using a recovery USB drive and finally if that doesn't work chances are it's hardware and being a chromebook it's often simpler to replace it.
Оценка 0
Добавьте свой ответ
amiller364 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 7
За последние 30 дней: 10
За всё время: 280
