Tv quit working after loud pop
Tv was on and working fine. Then a loud pop and the tv quit and will not turn on. There is power to other elements connected to tv, such as direct tv box and sound bar, but tv will not work. The tv is only about 4 years old.
Это хороший вопрос?
Оценка 3
13 Комментариев
lynnabbylucy what is the exact model of your TV and what have you checked?
из
Is the TV power light on?
из
Yes .....just had this same thing happen. Also t.b was really hot
из
Hello. Can you help me? I also have a problem with my Samsung plasma TV. It made a loud tickling sound and shut down. Now it won't turn on again. The red light on the side is blinking when I plug it. Thanks
из
Same thing just happened to me. A dynex tv
из
Показать 8 больше комментариев
Добавить комментарий
1 ответ
Выбранное решение
Usually a pop is a capacitor blowing or a fuse. Giving us the model number will help to find your exact machine. I would open it up a visually inspect it for blow fuses, burned spots swollen capacitors. Use a multimeter to check for continuity on any thing suspicious.
Был ли этот ответ полезен?
Оценка 9
15 Комментариев:
I got Samsung 55” model UN55F6350 (version WHO4). Just pop than shut off, any fix kit for this issue .? Tnx
из
Samsung 43" 4K Smart LED TV, 2018 Model UN43NU6900FXZA
из
Same issue last night. Loud pop and Samsung tv went out. Using fire stick at the time it happened.
Model #LN37D550K1FXZA
из
Same thing just now, model number UN46ES6150
из
The same thing happened to me my model number is QN75Q6DRAF.
Thank you.
из
Показать 10 больше комментариев
Добавьте свой ответ
lynnabbylucy будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 90
За последние 30 дней: 408
За всё время: 37,574
