Modern 4-slice toaster with seven toast shade settings, an anti-jam auto shut off, a removable crumb tray and extra wide slots with auto adjusting bread guides, a bagel option, and a retractable cord for neat storage.
What is the best way to clean the toaster?
Is it safe to use chemical products when cleaning the toaster?
Это хороший вопрос?
Счет 2
Добавить комментарий
1 ответ
Выбранное решение
Hi Alexus,
When cleaning you toaster, don't use any chemical products, that can ruin the exterior of your toaster. Cleaning your toaster is an easy task that just requires some time. If you want to clean the interior of your toaster (the crumb catcher and slots), check out this troubleshooting guide. If you want to clean the exterior of your toaster (the levers and knobs), check out this troubleshooting guide.
Hope that helps you out!
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Alexus Reyes буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 10
За всё время: 782
