a sheet, probably wrapped around
My washer is a stacked unit w dryER on top. The problem I have is it doesn't have the agitator.....it's a sheet, probably wrapped around the new style washer's middle thingy. Please help! Thanks!
Это хороший вопрос?
Это хороший вопрос?
Jennifer, You may have to remove the impeller/wash plate to get the sheet untangled from beneath it.
Below I will post a video, may not be your exact model but will show how a impeller is removed. In the future it is best to include all the info. you can make, model #,etc. as oldturkey suggest in order for ifixit to give best solution. Check the attached vid. link, Good luck.
Был ли этот ответ полезен?
How to remove a stuck Kenmore 500 Series Impeller?
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 4
За всё время: 1,611
1 Комментарий
Jennifer Rose, what make and model is your washer?
из oldturkey03
