Modern 4-slice toaster with seven toast shade settings, an anti-jam auto shut off, a removable crumb tray and extra wide slots with auto adjusting bread guides, a bagel option, and a retractable cord for neat storage.
5вопросов Показать все
Why is my cord not retracting on its own?
I am trying to put my toaster away, but the cord will not retract on its own. I have tried manually putting the cord back in but it is not working. How do I get the cord to retract again, or at least figure out a way to manually do it?
Это хороший вопрос?
Оценка 4
Добавить комментарий
1 ответ
Выбранное решение
Hey! It seems like there may be one of two things you can do:
  1. Untwist your cord - you'll want to pull out the entire cord and make sure it's not twist anywhere
  2. or replace the cord
Here are some instructions for solving both issues.
Был ли этот ответ полезен?
Оценка 4
1 Комментарий:
Thank you so much for your help @sydneyalcaraz ! My cord was only twisted and it was a very easy fix.
из
Добавьте свой ответ
Gabby Goymerac будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 863
