Released October 2013, identified by model number T100TAR-B1-GR(S). The T100TAR is a detachable tablet with a smart gesture-enabled touchpad and advanced connectivity.
7вопросов Показать все
Why is my laptop not charging?
Whenever I plug my laptop in, it doesn't charge. It only runs on battery power. I can't tell whether it is my adapter or my battery that is the problem.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Unfortunately, it is hard to determine if the battery or adapter is issue by just eyeballing it. If the adapter is the issue, you can test it by using another adapter, or simply buying a new one.
If the battery is the problem, then here is link to a guide that gives instructions on how to replace the battery:
Asus Transformer Book T100TAR Troubleshooting
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Alyssa Ballesteros будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 1,748
