The Polaroid OneStep 600 Camera takes and develops its own pictures. It features an automatic flash as well as a special lens for close up photos.
44вопросов Показать все
Вопрос закрыт
Re-usability of film and testing working ability.
I found the repair instructions informative but scary.
I have a Polaroid one-step but not sure if it works. When I press the shutter I assume I should see it close and re-open but I see nothing.
Does this only engage when it has film& battery inside?
I have film but I am unsure if it will be ruined if I test my camera with it and it does not work.
Any information available on testing working ability of this camera or re-using new film once inserted into the camera is GREATLY appreciated!!!
Это хороший вопрос?
Оценка 0
Добавить комментарий
3 Ответов
Выбранное решение
Yes you need the film in the camera because the battery is in the film pack. What will happen when you test is a picture will be taken and ejected from the front of the camera to process. The film cannot be reused and I would leave the film pack in the camera to keep from losing pictures. Here is a link on operating your camera.
http://answers.yahoo.com/question/index?...
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
Оценка 1
I actually have 2 of these cameras, so I'm well aware of this, mine are more aged tough, s one is from 1983 and the other from 1988
You will need a new film pack to make sure it's not the camera as the film pack is where the battery is, most likely the camera works(mine still do, I need cheap film), it's just a dead battery, you can get a Polaroid film pack with a good battery that ran out of pictures to test if you have a few, or someone has one for you and will loan it out
It only engages with a film pack because the battery is in the film, yes
No, if the film is no good, it won't develop properly, or won't develop at all, the camera won't be affected, so don't worry about that, if you take the film out of the camera, you'll lose an exposure more often then not
Оценка 0
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 3,670
