My battery wont keep a charge?
Whenever I try to use my laptop without the charger the battery does not keep a charge.
Это хороший вопрос?
Это хороший вопрос?
The most common problem is the actual charger, when plugging it in and no lights or notifications pop up on your screen the charger might be the issue. I would just look into buying a new charger if this solves your problem. If that doesn’t work, you might just have a problem in your battery settings. If you hold F2 it should bring you to a configurations window and under that go to your charger configuration. When you look at the charger configuration window set it to standard and your problem should be fixed. If neither of these solutions work I would check out this link for more solutions Dell Inspiron 11-3162 Troubleshooting.
Был ли этот ответ полезен?
@Omar Abas
You could try a universal adapter. Just make sure that it has the following specifications and that the plug is the correct type and size to fit the socket in the laptop.
Here are the specifications, which should be printed on the adapter:
Power 45 W
Input voltage 100 VAC–240 VAC
Input frequency 50 Hz–60 Hz
Input current (maximum) 1.30A
Output current (continuous) 2.31A
Rated output voltage 19.50 VDC
Alternatively you could search online for OEM Adapter Charger DELL INSPIRON 11-3162 19.5V 2.31A, 45W and check if any suppliers have prices that suit you
За последние 24 час(ов): 1
За последние 7 дней: 1
За последние 30 дней: 9
За всё время: 1,065
1 Комментарий
Hi! I lost my laptops charger and can't find it. I tried any charger or should i say universal charger to see if it fits to my laptop, but it doesn't charge my laptop. As it appears that my laptop can only use its original charger. I went to a computer shop and they told me that my laptop has detector in it, it only detects and reads the original charger. If i remove the detector or the sensor it would cost me too much. Is there any advice you can give to me? Please help me, i need my laptop for school works. My laptops model is DELL INSPIRON 11 3162.
из Omar Abas
