Startup repair cannot repair this computer automatically
So I booted up my pc for the first time and this came up:
Problem Signature:
Problem Event Name: StartupRepairOffline
Problem Signature 01: 6.1.7600.16385
Problem Signature 02: 6.1.7600.16385
Problem Signature 03: unknown
Problem Signature 04: 1647
Problem Signature 05: AutoFailOver
Problem Signature 06: 1
Problem Signature 07: NoRootCause
Anyone know what the cause of this error is and how to solve it? Cheers :)
Picture Attachment:
Это хороший вопрос?
Оценка 1
1 Комментарий:
Is this a custom build ? did you just install windows for the first time. and where did you get your copy of windows?
из
Добавить комментарий
1 ответ
Boot the computer while pressing F8. then have it start-up from the Last Known time it was working. See if that helps. If it boots up then you should go here. (If it doesn't then it is up to you what to do.)
http://www.askvg.com/fix-windows-7-keeps...
Install all 8 Windows 7 updates.
Then do the rest of the updates using the Normal Windows Updates.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Connor будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 1,784
