Not booting up properly?
I had liquid water damage on my MBP 15" unibody late 2008. I took it to Apple and as we all know its not covered. I ordered the correct motherboard and replaced it. Now when I go to turn it on it doesn't regularly turn on meaning I have to press the power button 30 times to get it to turn on once. I have reset PRAM and SRAM holding power button without battery and all the normal trouble shooting. When it finally does turn on the fans are on super high and the hard drive turns on but nothing else, nothing on the screen turns on. I don't have an external connector to check if it shows anything in an external display but I am going to check it out now and will update with what happens. It also does not charge the battery anymore. Any ideas would be great and helpful. Thanks
Это хороший вопрос?
Оценка -1
Добавить комментарий
2 Ответов
Наиболее полезный ответ
don't try to turn it on anymore,
please open it and clean up the stain, and hope there is no blowed up IC/SMT Capacitor or inductor(this one is blew up since you can't charge the battery anymore).
and hole the LCD cable didn't short out, otherwise you really need a new logicboard and also new LED screen, and also new LVDS cable.
or otherwise clean it up until there is no other trace of liquid and ask for flat rate repair, that will cost you $300.
other than that, you only can use the SATA super drive, the shell and the hardrive, battery, and also the glossy Glass with MacBook Pro logo on it.
Был ли этот ответ полезен?
Оценка 2
sounds
like more than just the logic board you bought was damaged... DC in and/or battery connector, keyboard/topcase damage.
Оценка 0
Добавьте свой ответ
Brian будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 1,016
