I cannot open my iPhone 5s
How can i open my iphone 5s? I cannot open it, whenever i press something there's someone speaking (for example i press the number for the passcode ex. n#1 it says n# 1)
Это хороший вопрос?
Это хороший вопрос?
Also sometimes triple clicking the home button turns voiceover off. Depending on how it's setup in the Settings > General > Accessibility.
If I remember correctly to navigate the things you can tap on slide down / up left / right on the screen until the thing you want to press on has a black circle around it which indicate that it is marked and double tap to do a 'tap'.
Two fingers slide up and down should slide a page up or down in the settings app.
Был ли этот ответ полезен?
You probably have voice over turned on. to select a number double click the number you want to select. and if you do get in go into setting>general>asseciblity (I dont know how to spell it) > voice over and then turn off it
За последние 24часов: 3
За последние 7 дней: 5
За последние 30 дней: 5
За всё время: 96
